grounding issues
Old Dec 28, 2011 | 09:25 PM
mrlazar75's Avatar
Default grounding issues
does anyone know where the ground from the negative cable goes? there are two wires that go off the negative cable, one is a chassis ground and the other has split loom around it and im not sure where it grounds. oh p.s. never let someone else touch your stuff and let them go to jail
Old Dec 28, 2011 | 11:04 PM
BasicConcepts's Avatar
Technical User
what engine and year
Old Dec 28, 2011 | 11:10 PM
iLL95's Avatar
I Like to Party
Super Member
Originally Posted by mrlazar75
does anyone know where the ground from the negative cable goes? there are two wires that go off the negative cable, one is a chassis ground and the other has split loom around it and im not sure where it grounds. oh p.s. never let someone else touch your stuff and let them go to jail :(
Care to explain? lol
Im sure the other ground would go somewhere on the engine, what year is it?
Old Dec 28, 2011 | 11:13 PM
Technical User
odds are it goes on the motor mount... there should be a stud somewhere around there
Old Dec 28, 2011 | 11:14 PM
mrlazar75's Avatar
haha crap sorry it is a 1997 camaro 3.8l manual.
Old Dec 28, 2011 | 11:17 PM
mrlazar75's Avatar
oh and the " never let someone else touch your stuff and let them go to jail" the guy who tore my engine down took everything apart went to jail for violating probation and i dont know where many of my bolts are and where all my ground wires go. oh and im not sure if i put the starter wires on properly because ive never seen a starter with 3 studs...
Old Dec 28, 2011 | 11:39 PM
Technical User
better check that starter before you put any power to it youll kill it if its wrong
Old Dec 29, 2011 | 06:44 AM
mrlazar75's Avatar
thats the thing. i dont know what to check for. anyone have ideas which wires go where on the starter? ive got 3 wires there a small one coming off the same harness as the sensor that goes into the block. i believe a coolant temp. sensor. i have the positive wire and i have a weird looking braided ground wire that comes off the chassis. not sure how they are suppose to be attatched. everytime i go to crank it nothing happens.
stewie
Feb 7, 2015 02:03 PM
allen707
Sep 25, 2011 08:55 PM
Masospaghetti
Sep 20, 2009 01:41 AM
ROCKOROLLA
Aug 20, 2008 05:41 AM
shnormo
Oct 24, 2006 08:59 PM
