Got a question
Got a question
Ok, so I'm building up my 95 Z with an aftermarket motor and was needing to know if there was such a thing as aftermarket motor mounts that will allow an older 350 block to bolt in to the existing location or what I would need to do. If anyone has anything it would be most appreciated. Thanks.
Mike
Mike
BMR make a Frame section that will work with a Gen 1 small block. It is not cost friendly but if you read through the above post your going to find that nothing about the swap is cost friendly. You could find a used LT1 with 30K on it install it in a weekend and have a lot less invested. Heck for what the above guy spent you could by a new motor.
