GM 1825M Antifreeze Specification
Old Apr 19, 2020 | 09:00 AM
ajmayro@comcast.net's Avatar
Default GM 1825M Antifreeze Specification
Does Prestone Antifreeze meet the GM 1825M specification for my 1994 Z28?
Old Apr 19, 2020 | 07:38 PM
gotta flush all the orange stuff out real good before using green stuff. they don't like mixing, turns into sludge.
Old Apr 22, 2020 | 11:14 AM
MKCoconuts's Avatar
GM spec 1825M is green coolant. They didn't start using Dex-cool until early '96.
OP, I would check under the radiator cap to see what color it is and if a PO may have mixed. Either way, if you don't have service history on it, now would be a good time to go to the local parts store and buy the cheapest coolant that says "concentrate" or "full strength" and flush the system out. Can be whatever brand you prefer, just look for one that has a green label. If it says Dex-cool anywhere on it, that is not it. Prestone in the YELLOW bottle with a black cap will work fine, regardless if you flush the system or not. The steel/gray looking bottle with an orange cap are Dex-cool compatible.
You can also buy it pre-mixed, but you're saving $2 to get half a bottle of water going that route. Clean drinking water will work fine or you can pick up a couple gallons of distilled water for less than a dollar.
premonition
Apr 15, 2010 07:03 PM
LT1RUNNER
Oct 11, 2007 05:34 PM
chevy camaro
Aug 30, 2006 07:12 PM
chevy camaro
Aug 10, 2006 06:38 PM
sshogun
Jun 10, 2006 09:52 PM
