Getting fed up with this car...
Old 07-10-2011, 10:11 AM
In addition to what Gorn stated, the "dead head" test does not really show how good the pump is. A good pump has both the proper pressure and volume. Choking the return line only shows the max pressure but does not give any indication of fuel volume. A weak pump may be able to build up pressure, but fail to deliver enough fuel to keep the engine happy. One of the better way to test the pump and regulator, but inconvenient to do, is to drive at WOT for around 15-20 seconds (depending on how much open road is in front of you) and see if the pressure holds while the engine is demanding maximum fuel.
Old 07-10-2011, 01:57 PM
305_camaro's Avatar
March 2012 Ride of the Month
Thanks for the insight, I like the WOT method lol. I live in a town where there are nothing but cornfields and cows so open road is not an issue. I may just be doing this test soon
Old 07-10-2011, 04:12 PM
Just make sure you are looking at the road, and not just staring at the pressure gage. lol
Old 07-10-2011, 04:43 PM
305_camaro's Avatar
lol i planned on having a passenger for the gauge lol, dont really need to total this car. What pressure should i be looking for?
Old 07-10-2011, 04:44 PM
305_camaro's Avatar
Also, if the regulator is the only thing that is bad what would it cause?
Old 07-10-2011, 05:07 PM
tjsmar's Avatar
hate to be teh noobz lol but what do you mean by WOT lol. and to where do you hook the pressure gauge too
Old 07-10-2011, 05:50 PM
Grandpaswagon's Avatar
WOT = Wide open throttle, pedal to the metal, east bound and down, etc.....
Old 07-10-2011, 05:55 PM
305_camaro's Avatar
^^Love this description
Old 07-10-2011, 06:37 PM
tjsmar's Avatar
lol ok i just wanted to make sure. Last question and Ill stop hijacking the thread lol, where do you hook up aa pressure gauge
  #20
Old 07-10-2011, 07:34 PM
305_camaro's Avatar
on the fuel rail towards the front of the upper intake, there is a cap and a valve(similar to a tire valve stem). if you turn the key to the on position it should push out fuel...mine hardly does
