general info on LT1 request
Old Nov 20, 2007 | 03:02 AM
Qlox's Avatar
Default RE: general info on LT1 request
Thanx for info
Old Nov 20, 2007 | 02:36 PM
95slvrZ28's Avatar
ORIGINAL: The Corvette Doctor
If you are buying off of eBay, you should try to get someone to check it for you before bidding. If not, try to bid only on ones where the seller says if you check the car and it isn't what we say, then you can back out without any penalty.
Unfortunately, there is a lot of junk out there. Some is on purpose. They know it is junk and they are trying to find someone who will get stuck with it. Some just happen. Some dealers buy many cars through the car auctions (dealers only) and some are good and some are bad. However, some of these dealers are one- or two-man shops that simply buy and sell cars. They may not have a garage to check and repair and sometimes they get bad cars that they don't know or that they fixed wrong.
Anyway that it happens, you still end up with a problem.
If you find a car on eBay, post here and other forums asking for someone to checkit for you. Most forum members on most forums will do it for free, also a small gift of dinner for two or something is a nice gesture for their time. You can also hire experts to check them.
The LT1 is like most Chevrolet V8 engines - tough. They last a long time normally. They do break, but usually from abuse, and that is often more abuse than a lot of other brands will handle.
From what I hear, three issues I know of are the water pumps tend to go bad around 100,000 miles +/- 20,000 miles. In the earlier LT1s, the water pump leaking will ruin the OptiSpark distributor, so it will need replacing at the same time.
I also have heard that the heads are susceptible to cracking from overheating, so if the water pump is leaking for very long, the engine could have overheated and cracked the heads. Maybe someone else can verify this.
Good luck.
All heads are susceptible to cracking from overheating...I've never heard of LT1's having any particular issues with this, no more than any normal car at least. The heads in the LT1 are the first thing to get cooled off(reverse flow cooling system which allowed for the stock 10.5:1 compression, you can actually push it to 11.5:1 on pump gas if you get it tuned correctly), so unless you're dumb and don't watch your guages the heads should be fine. Any opti will have issues if it's getting leaked on, although after '94 they went to a vented opti to help evaporate moisture that got into the opti, it helped but didn't completely fix the issue.
Good luck finding your car!
Old Nov 21, 2007 | 10:58 AM
Qlox's Avatar
BTW,
1993 - 1998 Camaros have LT1 ? AmI right ?
Old Nov 21, 2007 | 12:22 PM
ninetysixyenko's Avatar
1993 to 1997 had LT1s(some, SSs of 96 and 97, had LT4s). 98-02shad the LS1.the 93-96 v6s had 3.4s, some 96s till 02 had 3.8 v6s.
Old Nov 21, 2007 | 01:06 PM
Qlox's Avatar
Hmh. I found some 98 camaros with 280 hp for sale in Germany. Are they LT1 or LS1 ? Price for them is not so high.
Are there many differences between LT1 and LS1 ? How about performance ? ( TQ are about the same )
Does only bolt ons will make thies two equal, or is it worth to buy one with most hp ?
Old Nov 21, 2007 | 03:08 PM
aleksandr's Avatar
If they are 98 then they are LS1.
Old Nov 21, 2007 | 06:05 PM
280 is either underrated or RWHP for the 98. LS1s are a much better beast than a LT1. about a extra 80BHP, and what, 30TQ?
the LS1s are also much more affected by bolt ons. but the LT1 is a perfect motor for a stroker. a LT1 with full boltons would be about neck and neck with a LS1.
Old Nov 22, 2007 | 01:49 PM
Qlox's Avatar
What excacly is strocker?
Twin strock engine, like bike's?
I think, i won't go above bolt ons
mastiffd
May 19, 2014 09:08 PM
lemontime
Oct 31, 2011 07:00 PM
craby
Aug 4, 2011 09:26 AM
z28pete
LS Series Tech
Jun 20, 2007 06:59 PM
