Gears
Hm so i think its about time to up the gears from 3.42 to 4.10
what do you guys think?
what al ldo i need to do this (ill prbably take it to a shop to have done), would i just need a ring and pinon and their corresponding install kit or do i need a posi or w/e and otehr things? (this is going on the stock...what am i a #3?)
I think all you need is a ring and pinion set. I would also have the seals replaced. If the rear is not a posi. whats the point. I dont know the state of your car, but in my opinion, I would only go to the 4:10 gear on a sound drivetrain and fresh motor.
so wait...
how do i know if my car is posi? did they come stock with it?
Ok so id need a series 4 carrier(i thought it only went up to 3 something lol, all i have is whatever is stock), an install kit, and the actual ring and pinon?
and the motor has less than 2000 miles on it, and the drivetrain 100k
would 3.73s be better then?
i dont know what ur carrier is, but yes, the Z's have posis stock. i think the 3 series is the smaller, so to go up to 4.10s u need a 4 series. im not sure about all that either. i outsource my gear work
![Big Grin](https://camaroforums.com/forum/images/smilies/biggrin.gif)
you can getthe packagefrom texas speeds and spect is rite for 4.10's you need a series 4 carrier so if your car has 3.42's you can move it up to 3.73's with this package > http://www.texas-speed.com/shop/item...54&catid=6
