Gauge Cluster Problem
Old Oct 20, 2010 | 08:06 PM
Sage0114's Avatar
Default Gauge Cluster Problem
I am looking to buy a 98 z28, 6 speed. Everything functions normal except for the Dash cluster. The odometer, speedo, and volt gauge work, however everything else (Tachometer, engine temp, and fuel gauge do not. Also, all of the lights are lit up ie Check engine, handbrake, low oil, etc) Does anyone know what this could be and if it is an easy fix? Could it be just a bad sensor or sensors? Fuses? Maybe bad wiring? Or something more serious? Thank you for any input you could give me!
Old Oct 20, 2010 | 09:40 PM
BasicConcepts's Avatar
Technical User
im thinking with all the gauges not working theres a wiring problem
80z28guy
Apr 4, 2011 11:51 PM
luciora
Apr 23, 2010 04:21 PM
19 camaro 84
Jun 19, 2008 08:29 PM
brad87
Apr 26, 2008 10:37 PM
