Fuel Pump Hatch, and Suspension Question
Old 02-18-2012, 06:52 PM
Mikey.'s Avatar
Default Fuel Pump Hatch, and Suspension Question
Hey guys, just finished the fuel pump swap and thought I'd show you how the hatch came out. The car is running a lot better by the way. I was having problems with intermittent starts. It's nice to turn the key and it start right up.
Here's the cut itself, and the rivnuts installed:
And here's the plate installed and painted:
There's a thick gasket under the plate, so the dips in the metal don't really matter.
My question is about F body suspension. My car has about 185k miles, and is starting to get a bit bouncy. What do you guys recommend refreshing to get it riding right again?
Old 02-18-2012, 07:06 PM
get some good quality shocks, i recomend koni adjustables if you can afford em, bilsten makes some good ones too. the ride and handling of these cars are dictated by the quality of the shocks, you will not believe the difference it will make. add some sway bars and a shock tower brace while your at it. and check your tie rod ends. ive got some koni's and strano sway bars and love em.
Old 02-18-2012, 07:22 PM
Mikey.'s Avatar
When it comes to shock tower braces is there a huge difference between them? There's a couple on ebay for like 40 bucks. Are they a waste?
Old 02-18-2012, 08:19 PM
founders? the stb would be ok to use. dont think i would trust the lca's or sway bars.
Old 02-18-2012, 08:22 PM
libertyforall1776's Avatar
What Craby said, plus a Fays2 Watts Link in the rear, and some welded subframe connectors. Look at the Strano 35/22 hollow sways.
The STB was the 1st suspension mod I did, and yes it made a difference. I would go with UMI -- quality company, the owner is self-made -- I've met him...
Old 02-18-2012, 08:41 PM
Mikey.'s Avatar
Do you guys know of a good place to buy these things? I've had some trouble with random websites before. My otvc wires took a month and a half to get here.
Old 02-18-2012, 10:25 PM
Old 02-18-2012, 10:28 PM
Mikey.'s Avatar
Originally Posted by libertyforall1776
His prices are a lot better than some others I was looking at. (Strano's)
If I was to buy the Billstein set, what else do you think I would need (or should go ahead and get) to complete the install?
First time messing with the suspension.
Old 02-18-2012, 10:51 PM
strut spring compressor. if you order from strano call him. great guy, tell him what you have, what you want and he can set you up. one of the best suspension guys in the country.
Old 02-18-2012, 11:02 PM
Mikey.'s Avatar
We have a spring compressor here.
I'd want to have the money before I called him.
Is it normal to have to replace the bump stops ect?
Quick Reply: Fuel Pump Hatch, and Suspension Question
