Fuel Pressure Regulator?
Old Mar 6, 2011 | 02:31 AM
Massey's Avatar
Originally Posted by sebi1990
ok massey i tried it and i think you're right it might be the fuel pump...now what are your ideas on solving this?
Try replacing a fuel pump.
Massey
Old Mar 6, 2011 | 07:47 AM
could also be a failing fuel pressure regulator.
Old Mar 6, 2011 | 02:52 PM
sebi1990's Avatar
yeah I've tested the fuel pressure regulator it dose not seem to leak or anything I guessing it might be the pump is there any way I can check to make sure whether its the FPR or the Fuel Pump?
Old Mar 6, 2011 | 06:58 PM
here you go. got this from here,
http://shbox.com/1/4th_gen_tech2.htm...essure_testing
What the factory manual says to temporarily install, is a set of "fuel line shut off adapters" (probably something the normal guy is not going to have available). You remove the fuel lines from the rail and connect these valves in between. This lets you shut off either side of the lines for testing.
You can do the same thing by pinching the flexible lines to shut them off, but risk breaking them. You might be able to do it (your risk) by using a needle nose vise grips and putting some scrap hose as cushions on the jaws. Then use that to clamp off the line just enough to seal it. Obviously, this is not the best way to shut off the lines and could result in breakage. Heat and age can make the hoses brittle. If you don't want to risk it, don't. It's just a suggestion.
i used some cardboard folded over. i also slid the cover to the fuel lines up so i could get to softer fuel line that hadnt been made brittle by the sun and so on. you clamp the return line which is the small one.
royco95
Aug 2, 2015 10:25 AM
Kendagenius
Aug 13, 2010 08:34 AM
chadillac4110
Sep 17, 2009 08:43 AM
typeomang
Jul 18, 2008 07:43 PM
HURSTLT1
Dec 26, 2005 11:18 PM
