Fuel pressure question
when i turn ignition ON engine OFF i get about 47psi fuel pressure, however after about 5 seconds it starts to drop off and within 25 seconds its down to about 30 psi.
Is this normal?
Trying to diagnose a slow start issue - once its running its perfect, but at random it takes a good 5 seconds of turning over before it starts. No missfires, no codes.
Once running, fuel pressure readings are correct and within range.
Is this normal?
kinda normal for some pressure to bleed off. not all do it. usually fuel pump back flow valve is not sealing but can be a injector or fuel pressure regulator. the rear i would clean everything up to make sure its not running down the torque bar from trans or engine. stupid drain plugs on mine dont like to seal so i get some of that if i dont pay attention.
There was fuel in the vacuum hose on the fuel pressure regulator, so think i'll replace that since its cheap and easy and go from there.
royco95
08-02-2015 10:25 AM
BoricuaHec01
LS Series Tech
03-17-2011 05:56 PM
