Fuel pressure goes to zero
Hello all,
I have a 93 Z-28, all stock as far as I know. I just replaced the fuel pump, fuel filter and the car runs. However, the fuel pressure at the schader valve drops to zero after I shut the car off.
There does not appear to be any gas leaking, nor any gas fumes.
How can I determine which end of the car is causing the pressure loss (engine or fuel pump)?
Thanks,
Thanks,
u could pull the fuel rails off and then prime the fuel pressure up. if u see fuel leaking from one of the injectors u found the problem. if not then u would need to look at the fuel pressure regulator, any fuel leaks and the fuel pump. probly should look for any signs of fuel leaks right on down the fuel lines. look for a darkened and or clean spot. smell for gas too.
royco95
08-02-2015 10:25 AM
BoricuaHec01
LS Series Tech
03-17-2011 05:56 PM
