Fuel Pressure 94 3.4 V6
Old Mar 15, 2014 | 02:36 PM
Mikeroc283's Avatar
Default Fuel Pressure 94 3.4 V6
What is the fuel pressure suppose to be in a 94 V6?
Old Mar 15, 2014 | 03:23 PM
MKCoconuts's Avatar
Key on, engine not running should be between 41-47 psi. Running should drop 3 to 10 psi
Old Mar 15, 2014 | 04:05 PM
Mikeroc283's Avatar
Tested at around 36-38 at idle after start up a little driving. Went to 43-45ish i think with revs.
Old Mar 15, 2014 | 04:21 PM
MKCoconuts's Avatar
So you're within specs.
Old Mar 15, 2014 | 05:28 PM
Mikeroc283's Avatar
Still getting bad mileage though. Had 150 for a full tank to empty.
Old Mar 15, 2014 | 06:24 PM
MKCoconuts's Avatar
When was the last tune up? Could also try modifying your driving habits. A good fuel cleaner may help slightly.
Old Mar 16, 2014 | 07:55 AM
woh 8-9 mpg,,, maybe a plugged cat, have you had it scanned for trouble codes?
Old Mar 16, 2014 | 03:44 PM
Mikeroc283's Avatar
inside of the cat doesnt exist. wont scan i tried already with the scanner at work. Plugs were changed in october after i got the car, wires were replaced mid last month with 8.2mm taylors i ordered from summit, changed the coils because i did research and called for factory replacement specs which were LOWER than the accel's i installed. Any thoughts on the map sensor causing some of the mileage drop?
Old Mar 16, 2014 | 04:58 PM
is the exhaust unusually quite? cat can go to pieces and plug the muffler.
Old Mar 16, 2014 | 05:02 PM
Mikeroc283's Avatar
No. Loud like it always is.
