Front marker light install
Old Jun 11, 2010 | 11:49 AM
kpmunt's Avatar
Default Front marker light install
New to forum and Camaro ownership.
Just bought a set of Halo lights and the kit included the front marker/blinkers. The headlights mounted easily and work fine. The markers seem to be WAY too big. The opening in the bumper cover is roughly 2" but the replacement lights are tapered from about 3 1/2" down to maybe 2". Seller of the lights says they are right, I say they can't be. Am I missing something? Are all 4th gen marker lights the same regardless of model: base, RS, Z28 etc?
Any help appreciated.
Old Jun 11, 2010 | 12:09 PM
BasicConcepts's Avatar
Technical User
the lights are all the same on all models if they dont fit the only thing i could think of is to dremill the hole but i wouldnt do it for risk of fckin it up
http://www.topgearautosport.com/part...er_Lights.html
Old Jun 11, 2010 | 12:12 PM
kpmunt's Avatar
Default lights
Yeah, just installed a new bumper cover and am not interested in trying to "adjust" it to fit the lights.
Old Jun 11, 2010 | 01:14 PM
DarlingReject's Avatar
Prettiest Sixer Around
September 2010 ROTM
They fit. Well they should at least. They look huge, like only half of the actual light shows through. But you can't installed them from the outside, you have to take the headlights out, install the parking lights from inside, then put the headlights back in. There's only like a screw or two holding them in. They sit on a little bracket.
Old Jun 11, 2010 | 03:03 PM
kpmunt's Avatar
So that oversized light actually will work in there? Somewhat setback from where the original is?
Old Jun 11, 2010 | 03:53 PM
MaxTheKiing's Avatar
Yes they fit, i have the same ones in my car.
Old Jun 11, 2010 | 06:33 PM
DarkKnight's Avatar
GTO Killer
LimeKnight
they fit fine but it is a pain to get them on with the nose on... just unbolt the nose... its a whole lot easier, youll just need one other person to help aline it back on
Action Auto Rebuilders
Jan 13, 2015 08:16 PM
bigblock79z28
Nov 21, 2009 10:30 PM
New2Camaro
May 9, 2009 08:14 AM
shakespearesdad
May 4, 2008 07:20 PM
