Friends car wont start
See if the coil is mounted on the firewall, and if there's small module about 1.5" square near the coil. That's an ignition module, and mine would overheat after running a while and kill the engine. Can't remember if a good clean grounded mounting is important for it, but it's worth a check. If it has that module, pull the plug and make sure there's a good connection.
well, took off the distributor cap, and one of the wire going to the ICM looked corroded, i cleaned it up but the car still wont start, im thinking maybe since it got corroded and didnt make proper contact, it somehow fried the ICM? possible?
