a few things
Old May 23, 2008 | 10:25 PM
meteoralp45's Avatar
Default a few things
ok...theres some things i want to do....first, i want and o2 elminator for my car...so my car thinks i have cats so that my ses light will go off and i can pass inspection, and i will also just straight pipe after that..two, i want to get rid of my A.I.R. system, stupid p.o.s. tree huggin system, and i also want to get rid of my donkey ****...(the long tube patruding off of my intake system, thats after the air box and kinda just shoots down to the botom of the car....
can anyone help me with these things???
Old May 24, 2008 | 08:18 AM
Default RE: a few things
basically what im asking is, is there a delete kit for the a.i.r. and where can i find an o2 eliminator, and how can i block off the donkey ****
Old May 24, 2008 | 08:38 PM
95slvrZ28's Avatar
The A.I.R system is an electric pump that only comes on at startup to help heat the cats faster, so it doesn't rob any power. You can pull the pump and save yourself about 20 lbs, but that's about all it's going to do for you. If you do that you'll get your SES light back because the car is missing an emission component (if you have a visual inspection for emissions you will not pass without your A.I.R. system). To get rid of the Donkey Dong you'll have to get either a 1LE intake elbow or an aftermarket elbow such as the Trickflow that doesn't have the resonator on it. Once again, really not going to get you much in the way of HP. As far as O2 sims go, you can check out Summit and Jegs, you can order them there.
BareCat
Mar 22, 2014 09:22 AM
94z
Nov 3, 2008 09:04 PM
86whiteirocz28
Apr 20, 2007 10:07 AM
Deezil13
Nov 4, 2006 01:04 AM
