Fender badges
Old Aug 29, 2008 | 01:31 PM
Soopernovaaj's Avatar
Default Fender badges
hey guys, I was gonna take the z28 badges off the sides of my '00, and in its place put the 1969 z28 badges. my question is, should I put on the '69 fender badges, or the '69 tail panel badges? the tail panelbadges area bit bigger, more like the size of the '00 z28 fender badges. They'll both work, just a size issue. If someone here happens to have a '69 z28, could you possibly measure them for me? that would be great! also, the '00's are just stick on right? there wont be any holes when I remove them? Thanks and sorry if its worded weird, I'm kinda a noob...
Old Aug 29, 2008 | 01:49 PM
02StanGT's Avatar
Default RE: Fender badges
They are just stuck on there, unlike Ford who decided that all the trim pieces needed to be snapped into holes, so you cannot take it off without looking like a yahoo or filling the holes in.
Old Aug 29, 2008 | 03:42 PM
The 69 emblems have mounting studs. You'll need to cut/grind them off so you can stick them on with mounting tape.
I'll get you dimensions later. Car is at home, I'm not.
Old Aug 29, 2008 | 05:44 PM
thanks a lot man! yea i knew about the studs, no problem at all. my dad has a couple 69's, but no Z's. I really appreciate it.
Old Aug 29, 2008 | 10:36 PM
Side fender emblem: 4 1/2" wide, the "Z" is 1 3/4" tall, the "28" is 1" tall, the "/" is 2 1/2" tall
Tail panelemblem: 5 1/4" wide, the "Z" is 2 1/8" tall, the "28" is 1 1/4" tall, the "/" is 3" tall
Old Aug 30, 2008 | 01:08 PM
th3po1son's Avatar
get some pics as soon as you do it, i think it might look sort of cool
Old Aug 30, 2008 | 03:47 PM
fo sho fo sho. as soon as a Classic Industries box ends up on my porch...
Old Aug 30, 2008 | 04:19 PM
skylinrcr01's Avatar
i think the classic industries ones(depending on which ones you get) are like a 3d high quality sticker
Old Aug 30, 2008 | 05:50 PM
randopium's Avatar
i was planning on doing that too. so keep me updated with pics.
Old Oct 2, 2008 | 04:14 PM
well I've had the badges for a couple weeks now, just been slacking in putting them on. They DID need to be de-arched btw, super easy. just set em on the ground and step on them gently. I should have some pics up by end of the weekend.
red67coupe
Sep 6, 2011 08:09 AM
purpl96
Aug 22, 2007 09:59 PM
vampyrico
Apr 12, 2007 10:25 PM
