Exhaust work
some tools are just worth owning. A "sawzall" is one of those tools. $25 and includes a few blades
6 Amp Heavy Duty Variable Speed Rotating Handle Reciprocating Saw
I couldn't live without a sawzall. That one at H.F. is only $21 with your 20% off coupon. How much is the rental at Home Dopey? The small cost difference makes buying one a no-brainer.
good call, i do have a neighbor who has a saw i can use...it isnt the same as a sawzall so if it doesnt work right i think i will just buy one, because its $15 for a 4 hour rental so yeah more cost effective to just buy it.
the muffler, clamp, and sealant should be here by next saturday...the worst part about ordering parts is waiting for them to arrive
Sawzall on exhaust? I have a sawzal for home remodeling. It has never been in my garage. You guys ever used angled grinders with cutoff wheel. If it takes me a minute to cut off a 2-1/2" pipe it is because I do not want to put my beer down.
4-1/2 in. 4.3 Amp Angle Grinder
Remove the guard and add some of these
4-1/2" Ultra-Thin Cutoff Wheel for Metal, Pack of 5
In shops around the country this is affectionately referred to as a death wheel. I like to think it has that name because it will kill anything. It can cut through anything short of carbide.
A "sawzall" yes is wonderful around the home but also good for getting that blade into a tight spot where Mr cutoff wheel just won't fit.
I am more of a torch guy but when I did the muffle on my 96 I just remove the hangers let it drop down and buzzed it right off. Took longer to get the car on jack stands then it took to get the muffler off.
I am not say the sawzall with a metal blade will not work it just seems like a lot of work. I think you would have to put your beer down and use two hand with a sawzall. Who wants that?
With a sawzall, I can buzz through an exhaust pipe in about 15 seconds, without needing to drop the system. Not to mention (ok I am), sometimes you need to cut pipe before you can drop it. And, if I hold some beer in my mouth for a few seconds, I can be ready for the next swig right after the cut! lol
My cutoff wheel, that needs at least 2.5" clearance all around, isn't going to work when the pipe is close to the frame and floor. The sawzall also works great on impossibly stuck bolts such as shocks, etc., where you can cut between the mount and bushing. Try that with a cutoff wheel which has a very short reach by comparison.
