Exhaust Manifold Repair Leak
Get some PB penetrating oil and spray the manifold bolts at the heads and also at the connection to the Y tube. Let it sit a couple hours and it will save you that much time or more trying to get the bolts loose.
does not show a order of tightening but 18 ft lbs for the exhaust manifold bolts. if u need a break down on the way the other stuff goes on i can get a pic up for ya. this is for a 93 3.4 camaro vin code s.
