Electrical Problems
call or messge before and make sure included is the harness that plugs into the main computer. you will need to access the wiring behind the glove box where it ties into the under dash harness. and yah the 93-96 dashpads cost even more.
Ok. I have tried several salvage yards in my area and I can't locate a dash that will fit my year model, is there a place online i can try. I have a dash from a 97-98 model, it won't fit, the wiring and a/c hook is different.
thanks for your help with i really appreciate it.
97 will fit but its got different gages or gages use different volts. obd2. 94 is obd1. you will,,,, woh im not sure if a 95 will work, 93 94 and 95 are one year models for some things. i know the dash will fit from a 93 to 96 but i think you will need to have the guts (wiring, gauges and sensors/control boxs) from a 94. im not real sure on that. i know at least one of the 93 gauges are a one year thing. the tach. i thought you were talking about the dash top/pad.
The mechanic got the electrical problem solved, not sure what the issue was. I need to purchase a new fuel pump. The new steering wheel installed now I just need to decide to either pay some one to rewire for the dash i have or keep trying to locate one. Most of the salvage yards are damaged or already taken. Is there a way to add more horsepower to a stock v6?
The car is running good but the cooling fan will not work. If you turn the a/c on the fan will work. The mechanic checked the fuses and the relay as well as any electrical wires on the fan but he still can't figure it out. Any ideas?
