Electical issues
When I turn the car on the lights in the guages come on like they are supposed to. The odometer and trip meter light up like they are supposed to, but the radio doesn't light up and the window controls don't respond. The only button on the radio that responds is the recall button which makes the time appear for a few seconds then it dissappears. While this is happening the cigarette lighter and other plug are still functional. Usually after driving for a couple of minutes the radio comes on and the windows start working. They are not guarenteed to stay on though. Any help would be greatly appreciated.
its the bcm theres a sticky on how to fix it in the 4th gen section
here ya go i even found it for you https://camaroforums.com/forum/93-02...-repair-52062/ |
You didn't waste any time on that did ya. Thanks alot. Good to know it's not anything serious.
1 Attachment(s)
Apparently I need BCM removal for dummies. I have been prying on those clips for an hour and the only things I was able to budge are these...
Attachment 20078 I can't get anything else under there to budge. Any suggestions? |
are you trying to unplug the wire harness or get the bcm out of the holder
From what I have read you unplug the wires then slide out the BCM. The end result I am going for is getting the BCM out of it's holder
Thank you BasicConcepts and Craby. I finally just grew a pair and yanked on it and it came out. I reflowed the spots and now everything is functioning properly. A big thanks to Massey also for his thread.
New question. I drove my new camaro at night for the first time last night. when i turned the headlights on none of the backlights in the guages came on. Are they burnt out or is something else wrong.
did you try messin with the spin wheel by the headlight switch.
Originally Posted by craby
(Post 623332)
