EFan motor replaments
I just joined the forum and looking forward to learning, seeking assistance, and enjoying exchange of information. I have been a lifelong Chevy owner with three classic cars: 57 Chevy 210 2-dr station wagon, 87 El Camino, and 92 S-10 ext cab.
One reason for joining CF is I recently installed dual Efans from a 4th Gen Camaro as an upgrade on the 87 Elky. Unfortunately, the fan motors are squealing and I would like to find replacement motors. I would appreciate help with information on good sources and, if possible, part numbers.
Thank you in advance.
Thank you for responding. Unfortunately no, I don't know the specific source vehicle model as I was given the dual fan setup. As I stated, I am retrofitting the dual efans onto my 87 El Camino and using a Painless 30117 relay kit with 3 relays to control fan operations. As currently set up, it appears both fans function when either the AC or temperature sensor reaches 185 degrees F. I was hoping to have separate functionality of each fan: Fan #1 when temps reach 185F and Fan #2 only when AC is turned on. So, basically, both fans will run only when AC is turned on; at other times when temp is above 185F, only one fan will run to cool the radiator.
I would appreciate any comments and suggestions. Thank you.
Without seeing a wiring diagram for the relay system you're using, I can't tell how the fans are suppose to function. The fact that three relays are used makes me think that it could be wired to run the fans in a series or parallel configuration to control the fan speeds. It that is the case, both fans run all the time.
Luckily, I was able to find replacement motors on Rock Auto and ended up ordering 2 units. The url contains installation instructions manual and shows a wiring diagram on last page.
https://www.painlessperformance.com/Manuals/30117.pdf
Peter, I called Painless tech support and spoke with two techs on two different calls. After I explained the functionality I was seeking which was to have only one fan run when the temp reached 185F and the other fan run when the AC was turned on, he said I should have bought separate relay kits for each fan. However, to make this set up work as I wanted, I could cut the green wire and have separate fan functionality. After I hung up and examined the diagram, I wondered whether there was an optimal location for cutting the green wire--after the location where the blue and green wires are joined OR after the relay and before the diode. Upon re-calling tech support, I spoke with another tech who told me the functionality I sought was not possible with this setup.
So, at this point, which Painless tech do I believe? Looking at the diagram, which tech is giving the right information? What do you think?
Thanks Peter...I decided to leave the wiring alone and just run it as designed. Since installing the new motors, what happened the other day is intriguing. With both fans running and in stop-and-go traffic with little air movement, my stock engine temp gauge registered in the extreme range. So, I pulled over to check my cooling system and was surprised to find it was not about to boil over; I was able to touch the radiator end tanks which were hot but not scalding. Since then, I have driven it around without incident but keeping a sharp eye on the gauge and carrying a jug of water handy.
