Dying fuel pump.
Old May 26, 2012 | 06:54 PM
vanquishfist's Avatar
Default Dying fuel pump.
I'm pretty sure my fuel pump is almost done. It's been taking longer to start and hesitating under mild acceleration. Also a few times it's run really rough after restarting it in hot weather for a minute or so.
So I checked the fuel pressure and it won't go any higher than 22-25 psi. Should be 48-55 according to the manual. Took a vacuum line off and it wouldn't stay running unless I gave it some gas, pressure still didn't go much higher, so that seems to rule out the regulator according to the other threads I read. It's a wonder it's still running as well as it does.
Before I dump a few hundred on a new pump I want to make sure my diagnosis is correct with you guys.
Thanks a bunch!
Old May 26, 2012 | 07:13 PM
Filter?
Old May 26, 2012 | 09:24 PM
Yeah I should change that first.
Old May 27, 2012 | 12:48 AM
from the gas tank side dump the filters contents into a clear container. if its clean your pump is on a short fuse and could strand you somewhere at any time. if the pressure is the same running as when not running i would say its the pump. it would take a really pluged filter to prevent pressure to come up when the motor is not running.
Old May 27, 2012 | 11:08 AM
androzer's Avatar
thank god that it has symptoms that it's failing, some times fuel pumps they just stop working in the middle of the road.
Old May 27, 2012 | 11:36 AM
I can't even get the filter off. The quick connect came right off, but the threaded fitting is rusted on and my wrench keeps slipping off. I caught the contents into a container and there seemed to be a little sediment of some sort but I don't know if it was from the filter or debris from outside of the filter that came off when I loosened the quick connect.
Old May 27, 2012 | 11:39 AM
was that from the tank side, cant remember which side has the fitting. if it was plugged you would bet a crabload of stuff. careful not to hurt the fuel line.
Old May 29, 2012 | 10:47 PM
I don't know how I missed your post craby, it never showed up in my subscribed folder with a new post.
Anyways, I did finally confirm the pump is bad. I bought a new filter and a fuel line repair kit, hooked the new filter and line directly up to the gauge, turned the key on, and the pressure still didn't even get up to twenty.
I found the AC Delco pump for $227 on amazon so I ordered one there. Over a hundred less than rockauto.
Amazon.com: ACDelco MU1846 Fuel Tank and Pump Module Assembly: Automotive
I have one quick question though, what is the preferred method/tool to cut the hatch?
Thanks
Old Jun 7, 2012 | 10:15 PM
Got it in and running Tuesday. Fixed three problems: slow starting, rough running after start up when warm, and hesitation under mild acceleration. All gone.
I was wondering though, what thickness should I get the plate to cover it? And where can I a piece of stainless steel for that?
Old Jun 7, 2012 | 11:31 PM
machine shop will have some. may get a good deal on a scrap piece that will work.
