DRL Module Location
Found it.
Your Day Time Running Lights Module is located behind the radio. Its a small black box the size of a pack of smokes and has 2 plugs in it. A blue one and a black one.
If anyne wants to illiminate their DRL, just find that box and unplug the blue plug only. All lights will work fine however, your auto ON ligtht feature will be disengaged.
Takes about 5 minutes to complete.
for some strange reason.. only one of my day time running lights was working.. My guess that it was the resisitor in the Module itself.. So instead of my worrying about getting the one light to come on.. it took .2874764 seconds to just turn the other one off.. done and done.
FYI - i priced out a new DRL Module.. and its 400 bucks! so thats also a good reason to do what i did.
Wonder if it's easy to add this module to a '95, since they had no DRLs?
Found it.
Did you check http://GMpartsdirect.com ? That prices sounds way out of whack.
