Driveshaft issues
Driveshaft issues
Ok, first i wanna say this site kicks a**. So i just bought my first camaro. Its a 1995 convertible. I did have to change the the engine in it. Anywhoos, i noticed the 2 piece driveshaft. I think whats called the carrier bearing is bad. Is this something i can buy at autozone...or is this a dealer item only? how hard is it to change out? can i just swap out the 2 piece for a one piece? If yes, witch one will be a direct drop in and be done with it? thanks for any info. Jason
p.s....I dont think it was a bad deal for $800.
Easy to remove, four bolts holding the rear U joint and 2 bolts above the carrier bearing, lower it and slide it out of the tranny. Have a pan handy incase tranny fluid starts coming out the tail shaft of the tranny.
You'll also not have to worry about the carrier bearing going bad because there isn't one
A little FYI...3rd gen and 4th gen driveshafts are interchangeable. So if you're not dead set on spending the money on a newer aluminum one, you can get one from a 1992 on up.
Oh, and when I put an aluminum driveshaft on my 96, then used the same one on my 91, I weighed the two. The stock steel shaft weighs 16 lbs. and the aluminum weighs 12 lbs. A savings of 4 lbs.
Even though your two-piece driveshaft assembly does weigh a little more than a standard one-piece, you're not going to be dropping 20 lbs of spun weight.
And if you're wondering, no I didn't notice a difference in performance.
oh ok, so 92 and up will work. im not really conserned about aluminum, i just want a direct bolt on. im still driving my car and it still vibrates like hell . hope to try and find one tomorrow. thanks again for all of your help.
im not exactly sure? its all stock if it means anything. this camaro is all still new to me. i couldnt even tell u what trans is in it. all i know is its a 4 speed automatic. when i pull the camaro in the garage later, ill post some pics of the under side. i didnt think the whole driveshaft thing was going to be a big issue. then again, i never owned a car with a 2 piece driveshaft either lol. any info will help me. i plan on pulling it out tonight and tring to find a used on tomorrow. thanks again for the help.
1995, 98, bad, bearing, camaro, carrier, chevy, cmaro, drive, drrveshaft, interchangeable, jersey, modifacation, shaft, south
