driveshaft
Old Dec 8, 2011 | 02:20 PM
iLL95's Avatar
I Like to Party
Super Member
how do you get the drive shaft out??? it has been about a year and a half since ive seen one
If you're talking about a 2 piece,remove the two bolts on the bracket then the four on the rear yoke. and then just simply pull the driveshaft back and out, it takes some prying or hammering but it should eventually come out, dont be surprised of tranny fluid comes out with it.
Old Dec 8, 2011 | 02:40 PM
BasicConcepts's Avatar
Technical User
i meant from the bearing lol
Old Dec 8, 2011 | 03:02 PM
Make sure you support the weight of the bearing and drive shaft. You do not want all the weight hanging on the tail of the tranny. Your rear does not have grease in it, it has Gear oil. It is more like 85w motor oil than it is like a grease. There is a fill hole on inside just about level with the Yoke in the rear housing.
NEVERLETITDIE
Jul 16, 2010 12:57 AM
Toneman07
Sep 8, 2009 10:09 AM
2fast4u
Oct 13, 2008 10:27 PM
