drivers door hinge
drivers door hinge
does anybody know where i can get a drivers side upper door hinge or replacement pins and bushings for my 93
every where i looked had plenty of passenger side or lower drivers side and no one had pins and busings
any help or suggestions is appreciated
thanks
Brad
thanks
Brad
lower hinge pin # 20262500 roller is # 20058035 does not show a pin for the upper hinge. these guys have the pins and rollers. GM Parts Direct: Your direct source for Genuine GM Parts
part number for upper hinge 16626519 is for the three hole hinge and not easy to find. only 93 and 94 have them.
two hole hinge is #16630875 and can be found
16630875 | RearCounter.com | 1 found at 1 dealer
