Double sided tape removal
Old Apr 25, 2011 | 09:41 PM
timmyz28's Avatar
Default Double sided tape removal
I am taking the body moldings off the Z and I was wondering what is the best way to get the double sided tape off the car and make it look all nice and clean?
And also, I'm repainting the berger panel and installing the Z28 and bow tie emblems back on. What's the best stuff to hold the emblems on tight?
Old Apr 25, 2011 | 09:52 PM
Phalen123's Avatar
Blow dryer and a plastic paint scraper thingy work best, and also after that use some Goo b gone on the surfaces, not sure about replacement tape
Old Apr 25, 2011 | 10:07 PM
timmyz28's Avatar
OK thanks, I'll give that a shot. I think I still have my plastic squeegie for tinting windows. That should work.
Old Apr 25, 2011 | 11:08 PM
Catmaigne's Avatar
If you want something a bit less potent than that Goo nonsense (not sure how it will affect paint), try mineral spirits.
Old Apr 26, 2011 | 12:00 AM
...or WD40. For the emblems, double sided emblem tape (go figure).
Old Apr 26, 2011 | 12:03 AM
timmyz28's Avatar
I have a few cans of WD40 and PB Blaster but I wasn't sure how they would act on the paint since I'm trying the scrub it off. I'll give that a try too. Can I use some type of silicon for the emblems? I have that here, but no double sided emblem tape.
Old Apr 26, 2011 | 12:06 AM
BasicConcepts's Avatar
Technical User
ive used super glue for emblems but the gel kind so it doesnt run it worked very good
Old Apr 26, 2011 | 12:09 AM
timmyz28's Avatar
I actually have some of that sitting in the garage!
Old Apr 26, 2011 | 12:16 AM
WD40 won't hurt the paint. Whether you use that or mineral spirits, you want to remove the oily residue with a cleaning solvent. Brake cleaner won't hurt for a quick clean. Never use carb cleaner on paint (that you want to keep). Silicone adhesive should hold, good prep (sand back of emblem) is key.
Old Apr 26, 2011 | 07:46 AM
timmyz28's Avatar
I'll try the WD40 and see how it works, thanks.
Yeah I have my emblem prepped and painted already. I painted it white because I painted the panel black. And I have super glue and a couple silicones so I'll see what will work best.
