Door opens with any key
I just found out the my passenger side door opens with any key or even a screwdriver. The key can only get about quarter of the way into the cylinder, but it still turns and unlocks. Thankfully my alarm goes off when the door is opened that way though.
Is there something I can do temporarily to the cylinder to make sure nobody breaks in? I assume I have to buy a pair of lock cylinders and use a seperate key now? Thanks all |
if you dont use that cylinder you can always disconnect it from the locking mechanism.
Could be worse I suppose, most of the time my door wont open no matter what key you put in it:)
On another note, do you have a nice stereo, and can I have your address:D |
Originally Posted by djsquare1
(Post 641676)
I assume I have to buy a pair of lock cylinders and use a seperate key now? |
Thanks for the tips. I will try soaking it with PB and see what happens.
I noticed my key wont go in on either of the doors, maybe there is a seperate key the owner never supplied me??? Either that or they are corroded like you mentioned. If all else fails I will disconnect the cylinder to the lock as I don't use keys unless my battery is dead. No comment on the stereo and location... lol |
Even a non-matching key cut, provided it's the door style key, will/should go into your lock, it just won't turn. I think you have some corrosion going on. I've had a couple locks corroded so badly that I had to disassemble the lock and remove all the tumblers to free it up. I don't recommend doing that if you don't know what you're doing.
(Post 641709)
Originally Posted by GreenMamba
(Post 641730)
Just to make sure since you wrote this, but you do have 2 keys right? A door key and an ignition key? From the sounds of it you only have 1, and the ignition key(the one with the chip in it) definitely shouldnt work on the door.
Yes I only have the ignition key |
You should have a round head key too, that's for the doors and hatch. It's no wonder why the key doesn't work.
Separate key for ignition and food. One is square and one is round.
