Door Handle Problem- Help
My drivers side doorhandle (outside) stopped working- the inside works as well as the lock- the handle just feels totally disconnected on the outside- what is involved in fixing this? I am assuming pull the door panel off etc- but what is the best way to attack it?
RE: Door Handle Problem- Help
i have the same problem when i sanded my doors, if you look at the inside of the door when its open on the side you can see a hanger type thing that connects to the door handle itself that opens the door from the outside, i will let you know more when i fix mine
