Done deal?
Old Jan 2, 2014 | 08:13 AM
  #51
Originally Posted by Cammy
.. after the starter problem the car for some reason overheated because my resovoir cap wouldnt cap on. the temp went all the way pass the last guage line.. after stopping and refilling the radiator the car shows no sign of response when trying to start..
2.
that defenitley got it starting.. thanks a lot, but it sounds really rough now any idea why?
3.
... its looks like ive got a blown gasket because water is coming out of the pistons on the side and there is white smoke coming out the exhaust
4.
... after long hours of of removing parts my buddy and i finally got to the head.. there was water in the pistons, im guessing it was in there for a while since the water made the pistons look brand new.. the gasket blew about a inch for water to flood in..
Here's the series of events based on your explanations:
Your engine overheated and pegged the needle, and you kept driving it like that for ten minutes.
After shutting it off and trying to restart, it wouldn't.
Once you did get the engine restarted, it has a bad sound where it didn't before.
After replacing the bad head gasket(s), the engine still makes bad sounds.
Responses to your quotes above:
1.
Yes you overheated the engine. Without being there I can't say what you meant by "no sign of response when trying to restart". If you meant the engine wouldn't turn over, then you "seized" it.
2. Makes sense based on what happened in #1.
3. A bad head gasket, but with serious side effects.
4. That milky oil was also in the oil pan, meaning it's likely that it did bearing damage, and possibly ring damage from the engine seizing, which explains the noisy nasty knocking engine I hear in the video.
Old Jan 2, 2014 | 08:40 AM
  #52
Man I need to read these posts better, I assume after finding the milky oil he had just replaced the motor. Dude sorry all the work was for nothing. As Camaro69 said that motor is done for. I would be very surprised if it made it 1000 mile before a rod bearing spun and seizes the motor.
Antifreeze in the oil is a death sentence for a motor. When put under high pressure the antifreeze turns into an acid and wipes out the bearings. Motors don’t come back for that, not even new ones.
Old Jan 5, 2014 | 02:58 PM
  #53
Cammy's Avatar
Thanks guys. Yes if only I got the news early, i would have saved up maybe for an LSx. The motor keeps having a burning smell and the oil gets milky after changing. Here is a vid after replacing the heater hoses... My plan is to buy a new motor since its done for. Thanks for the input anyways.
Old Jan 6, 2014 | 12:27 AM
  #54
Man, I'd be interested in tearing that engine apart just to see what happened. I'm hearing a sawing sound, which could be a spun bearing. Can't tell from here though from where the sound is coming from (top or bottom end). Sorry for your loss!
chrisdelk
Jun 19, 2009 12:19 AM
Z28man
Jan 25, 2007 03:50 AM
Taylor
Dec 3, 2006 03:04 PM
imawesome
Jan 1, 2006 12:44 PM
