Do I have to use premium?
for sure recomended, if you dont want to becuase it is more expensive just realize that on 20 gallons at 10 cents more per gallon it is only two bucks, i know anyone can figure that math but some times it seems like it would be a lot more, really for the problems it can cause it is really cheap and should make it perform a lot better
ya the premium is better but it is the gas itself that could be lacking, it sucks but the better the gas mobile, shell of course the more exp gas is refined better and there for in it self better then the cheaper gas staitions. long story short the better the product gas the less likly of problems down the road and in overall better proformince and longer lasting motor.
ORIGINAL: 8485Chevycowboy
Yeah, but the cost of gasoline at certain gas stations has absolutely nothing to do with the quality of gas in their tanks. Absolutely nothing. My Father was in the oil/gas retail business.
No, you don't need to run premium. A lot of people think that simply using premium fuel is going to boost your performance. Nope. Premium will boost performance (in reality prevent you from losing performance, I'll explain later) only if your engine requires itdue tohaving a high compression ratio. Yours has a 9.4:1 ratio, not what I would consider "high", but higher than other engines out there. Take a Nissan Maxima for example. That has a high comp. ratio of 10.3:1 and it definitely requires premium. In "old school" engines like my 69, running a lower octane in a high compression engine could eventually do damage, and the engine will give the old "marbles in the cylinder" knock. But, newer computer controlled engines have a knock sensor. So lets say your engine requires a high octane fuel, but you want to use a lower grade. Instead ofgetting a "marbles" knock, your knock sensor picks it up and retards the engines timing so that you don't get engine knock. And, retarding the engines timing from optimumwill cause you to lose performance, and most likely gas mileage too. I would play with 87 and 89 octane and see if you notice a change in either performance or gas mileage. You should run a couple of tanks of each and try to be objective and drive it the same way so that your right foot doesn't skew the results. And as was stated in earlier posts, you want to use a good brand of gas. Most of the gas we use comes from the same place, the difference between brands is the additives and detergentsthey put in, or don't put in. Premium octanedoes not necessarily mean good gas.
Confederate Air Force?? Didnt kno there were airplanes during the Civil War...
Anyway, can i just throw premium inthe next time i get to a 1/4 tank or do i need to get the old regular out before i put premium in?
ORIGINAL: Spartan66
Seriously though, the Confederate Air Force is now called theCommemorative Air Force. It's an organization thatpreserves and showshistorical planes at airshows. To answer your question,read my response above about premium fuel.
