difficult problem
Old Mar 10, 2012 | 09:27 AM
Camaroboi22's Avatar
Default difficult problem
Driving on highway going bout 65 crusing next thing i know car start puttering it was like the more gas you gave more puttering and slowing down. Then starts smoking from underhood then out the exhaust crazy had no power to get up about a 40 degree hill mean while still smoking and exhaust is popping. Get it home and the exhaust manifolds are hot red. Let it sit for 2 days starts rite back up sounds like the cars going run well so i take it down me street and it starts over again. Theres no check engine light on or anything. Any suggestions?
Old Mar 10, 2012 | 09:39 AM
Mikey.'s Avatar
The first thing that comes to mind for me is a clogged catalytic converter.
More information about your car would help. Year, engine, mods ect.
Old Mar 10, 2012 | 09:48 AM
^^^ agree it sure sounds like the cat or cats is plugged, if cat or cats went to pieces your muffler could be plugged. or could have a potato in the exhaust pipe.
Old Mar 10, 2012 | 09:49 AM
94 lt1 only has cold air intake and borla exhaust
Old Mar 10, 2012 | 09:56 AM
so one cat, or do you have a cat at all?
Old Mar 10, 2012 | 10:05 AM
it only has one i just bought the car bout 6 months ago and the exhaust and air intake was put on by the previous owner it has 210xxx miles and i was going change the motor but i dont want to know because i dont know if its a sensor or what ever it is
Old Mar 10, 2012 | 10:26 AM
you can try and losen the exhaust before the cat or take out a 02 sensor and run the car to see if the issue goes away. plugged cat will stop the flow of exhaust gases leaving unburnt fuel in the pipes which burns causing the red hot manifolds. did you notice if the cat was also red hot?
Old Mar 10, 2012 | 10:38 AM
honestly i never looked under the car at that time so i dont know so u think this is and exhaust problem?
Old Mar 10, 2012 | 10:50 AM
if you have a stuck injector or a couple cylinders that are not firing it will overload the exhaust with fuel and can cause a red manifold. ive only seen it on one or two pipes though. try opening the exhaust and see if that does it. be fun, open exhaust for a few minutes to wake the neighbors
Old Mar 10, 2012 | 11:04 AM
Lol i know cars loud already but ill try that then let you know how it turns out
