Dextron 2 for the power steering fluid?
Old Apr 13, 2013 | 07:56 PM
AmericanMuscle1989's Avatar
Default Dextron 2 for the power steering fluid?
Hi all,
I just wanted to check the correct fluid for the power steering.
Is it Dextron 2?
The fluid guide I found on here says
"Power steering fluid: Top off, Type GM hydraulic power steering fluid"
Would Dextron 2 be ok?
Thanks
Alex
Old Apr 13, 2013 | 09:20 PM
MKCoconuts's Avatar
They don't make Dexron II any more. All makes and models power steering fluid will work fine. Valvoline and Prestone both make it.
Old Apr 14, 2013 | 06:31 AM
dex will work, steering fluid is better formulated for it
Old Apr 14, 2013 | 10:00 AM
Do you have something against using power steering fluid for the power steering?
Old Apr 14, 2013 | 10:41 PM
1augapfel's Avatar
Use power steering fluid.
Old Apr 15, 2013 | 04:18 PM
Ive got nothing against using power steering fluid but here in england I am having trouble finding anything not dex rated.
Is dex 2 going to be ok?
Thank you
Old Apr 15, 2013 | 04:28 PM
MKCoconuts's Avatar
Thank you
If you can still get Dex II over there, it'll work, but Dex II was superseded by Dex III and that by Dex VI long ago. Other than that, really any bottle that says power steering fluid will work, so long as it's not the "Honda" stuff.
Old Apr 15, 2013 | 04:45 PM
OK cool, thanks very much guys
Volcente
Aug 2, 2013 04:37 AM
Chevra
Jul 31, 2013 09:02 AM
v64thgen
Nov 27, 2012 01:54 PM
LiMariee
Feb 19, 2010 11:14 PM
