Dash Vacuum Line
Old Dec 12, 2011 | 01:12 PM
iLL95's Avatar
I Like to Party
Super Member
Default Dash Vacuum Line
So a few months back, I had a problem with my A/C not blowing from the dash, with a little help I pinpointed it down to the VCV next to the computer, I took a look at it and it was cracked and broken. Well, while I was trying to take it off I yanked a little too hard and felt one of the lines give out (a line that looks like it went through the dash) I panicked a little and tried to push it back in. I replaced the VCV and the A/C worked again but now the line that got pulled is kind of pertruding out. Is it possible I pulled it out? could it possibly be causing the rough idle I've been experiencing? Is there any easy way to check it out or would I have to go completely through the dash? Appreciate the assistance.
Old Dec 12, 2011 | 09:12 PM
BasicConcepts's Avatar
Technical User
can you get a pic of the line and where it goes???
Old Dec 12, 2011 | 10:06 PM
iLL95's Avatar
I Like to Party
Super Member
Its dark, will first thing tomorrow morning.
Old Dec 12, 2011 | 10:32 PM
je$$up97's Avatar
not sure what line it is...but vacuum issues will cause idle problems.
Old Dec 13, 2011 | 02:25 AM
if the heater controls will switch from heat to defrost and such then i doubt you have pulled it off. could disconnect it and plug the vacumm side to see if it makes a difference.
Jelz28
Aug 1, 2012 04:29 PM
Z28Camaro98
LS Series Tech
10
Jun 3, 2012 06:52 PM
iLL95
Oct 4, 2011 09:25 AM
gfrench
Nov 5, 2010 08:06 PM
nitrojunkie
LS Series Tech
Oct 7, 2010 10:57 AM
