Damn PassKey II
Damn PassKey II
I'm putting together a 1994 Camaro from lots of parts.The steering column came from one car and the wiring harnesses came from another. The harness had the Pass Key II theft control module attached. Eaverything is connected and, when the key is turned, the "security" light lights on the dash and nothing happens, except for some relays clicking. I'm figuring that this is because the TDM does not match the steering column/key. Can I reset the module? Can I bypass the system? I understand that a new module comes unprogrammed,but I'mtrying to do the DIY fix first.
Thanks for any suggestions.
RE: Damn PassKey II
Never mind, I found the answer on another site. You cannot reprogram the module, but I found a friend who has a "dial a resistance" device. By working throught the 14 remaining codes I can determine the resistence by trial and error. Once the pellet code is found, I can orderthat key and have it cut to the correct mechanical shape.
Strange, if I asked which cat-back exhaust sounded cooler, I would have had 20 relies.
