Coolng fan amps ???
Old Apr 14, 2010 | 03:57 PM
67 455 Bird ragtop's Avatar
Default Coolng fan amps ???
Anyone know how many amps each cooling fan in a stock dual fan setup draws?? I have one from an LT1 I plan to run on my 67'Bird. Want to make sure I have the right amperage for the controller without going overboard.
Old Apr 15, 2010 | 09:57 AM
im showing a 10 amp fuse to run the fans so it should be about/less than that.
Old Apr 15, 2010 | 01:29 PM
It's always safest, and gives the most power to the fan, if you wire it up using a relay. If you wire it directly through a switch, it has to be rated to handle the amps. Some cheapo switches will have a melt down.
Old Apr 15, 2010 | 02:03 PM
Thanks for the info.
Bouyz28lt1
Jan 13, 2012 10:49 AM
skeets2469
Oct 4, 2010 09:14 AM
xxBladeFirexx
Jul 23, 2009 11:20 PM
