Coolant spewing out overflow
Rad cap. Had the same issue.
Pulled into my garage today and the temp guage hit the last line before the red. I thought it was running a tad hot so shut her off and popped the hood and coolant was spewing out the overflow tank. There are no leaks that i am aware of.
Any help appreciated! Could an air lock have caused this?
Thanks for your responses.
Filled with water, bled and replaced rad cap. Have driven around and problem hasnt happened again so have drained and filled with coolant. Am just praying it doesnt happen again..
Just a Q regarding bleeding, according to the notes i have read, after filling you should run engine with rad cap off, and add coolant as needed. Issue i have is as soon as the t stat opens, all the coolant just starts comming out the radiator so i end up just putting the cap on and using the bleed screws.. Am having no heat issues now. Needle sits at a quarter highway, goes just above half in heavy traffic
how much coolant is coming out? its normal for some to pour out when bleeding but should not blast out. I usually start bleeding with it cold with the heater off and holding the rpms at 2k until it gets to normal temp and the bubbles stop and then turn on the heater full blast and hold til 2k till the bubbles stop and repeat til i see no bubbles.
Its not until the t stat opens that the coolant starts bubbling out the top forcing me to put the cap on or risk loosing all the coolant. I am unable to leave the engine running at normal temp with the cap off as the guage keeps rising.
Rocketray
06-25-2012 11:24 AM
