coolant leak!!!
Hi im new here i had to pull my tensioner ***. today and the metal end broke off in the block !!!
any suggestions on how to remove the part still in the block ?
![](http://imageshack.us/photo/my-images/69/mmsimg899915403.jpg/)
ImageShack® - Online Photo and Video Hosting
Update!!
ok i got the piece out of the block by using a dremel tool with the cutting wheel. Tip the cutting wheel is almost as big as the housing so grind it down a bit on concrete or a junk peice of iron if not be carefull not to cut into the housing or you will have to fill the cut before installing anything. Make a cut not too deep but deep enough to stick a flat head screwdriver tip in it and pry it til it breaks off repeat until you get it out or get to the o-ring once you remove a piece of the o-ring it comes out easily !
http://imageshack.us/photo/my-images...835126582.jpg/
Im about to head to the junkyard and see if my pump assembly will interchange with a lesabre grand am assembly which uses plastic elbows on both ends !!
![Frown](https://camaroforums.com/forum/images/smilies/frown.gif)
Update!!
