coolant leak!!!
coolant leak!!!
hey guys
new to the forum and got a question. my sister has a 2000 camaro v6 3.8 with 145,XXX miles that has developed a leak. after a while the car starts to get really high on temp gauge and "check gauges" light turns on. i traced the leak to the bottom of intake and just above the water pump. after i turn the car off i can hear it hissing and see water leaking from that position. Is this a hard fix? and is this the intake gasket that needs to be replaced?
thank you and any help on this is greatly appreciated..
Coolant leak
I don't know enough about Camaro's yet so I'm not sure if this applies to a 2000 model but it definitely to my 1997. I heard a hissing right above the water pump and water was gushing out. All it is is a plastic 90 degree elbow that's behind the tensioner assembly and I didn't even have to remove the intake. I pulled too hard on the tensioner assembly and I broke it so I had to buy a new one for $60. Good luck.
https://camaroforums.com/forum/v6-te...anifold-41186/
Best thing to do is remove it and take It to the part store to match it. Oreillys has it on the shelf 2 for $5 easy fix. You need to remove the tensioner to get to it but its very easy and very common.
I think it's called a coolant bypass tube. Attached is a Youtube video about this common Camaro issue. If this happens to me again, then I'm swiching to a Mustang
YouTube - Chevy 3.8 coolant leak
make sure you do both elbows while you are in there! if one went, the other is probably pretty close.
