Convertible Tonneau Cover
Old Dec 27, 2012 | 01:08 PM
Randy Bilyea's Avatar
Default Convertible Tonneau Cover
Just ordered these. Hopefully they get here before it goes for paint!
Anyone have them on their car already?
Old Dec 27, 2012 | 05:30 PM
fbodyrs96's Avatar
There's quiet a few people on ls1tech with those, I know most of them have them bolted together or have built a brace to hold the center up, cause there so heavy, also if it rains your screwed, it won't fit in the trunk.
Old Dec 28, 2012 | 09:51 AM
Edwardgp's Avatar
I like them I think they clean up the appearance of the vert,IMO.
Old Dec 28, 2012 | 09:53 AM
They look nice for parades, not so user friendly when you want to put the top up or down on a whim.
Old Jan 15, 2013 | 02:14 PM
Well, they arrived today, and after getting them home, I found I had to modify the center mounting holes a bit. Whomever drilled them apparently was drinking their lunch.
Anyway, after getting that minor modification straightened out, I got them bolted up and set in place.
I think they look pretty good, obviously much better after they get painted with the car.
They come with 4 oversized thumbscrews to hold them together, which will allow me to take them apart to set them on the back seat if I need to put the top up unexpectedly. The will not fit in the trunk, even if I took the sub box out.
Once I get it on the road I may want to fabricate some kind of vertical brace for it from the middle bolts down to the folded backseat, just to keep it from bouncing if it becomes a problem. Time will tell.
Here's what it looks like now. Crappy blackberry pics and the car is dusty as hell from being in the shop for a couple of months...
Old Jan 15, 2013 | 04:32 PM
BasicConcepts's Avatar
Technical User
I was looking at those when I had my vert, I wanted them soooooo bad.
Old Jan 9, 2024 | 01:17 AM
Rdf503's Avatar
You still got the car? Would like to see what they look like when finished. Thanks
belliott
Mar 26, 2012 04:07 PM
Jrbrent23
May 24, 2009 06:29 PM
Jrbrent23
May 24, 2009 06:25 PM
