computer problems
94 3.4 camaro i've been HAVING SOME PROBLEMS WITH MY idling its idling to fast ive got it check they said change the IAC i did its still doin it so we considered it was the computer if anyone happens to know the computer numbers please tell
please tell r if theres none say' r does IAC goin any certain way i jus removed 2 screws and put it in and started it, it reved at 2500 rpm this was the new IAC ,i dont know if it takes time for the newone to kick in r something
I have a Z-28, so I am not positive if this would help. But when changing the IAC you need to measure the distance between the tip of the valve and the mounting flange. On the LT1 it needs to be under 28mm, and if its not you need to retract it by pushing in the tip. After it is installed the valve needs to be reset. on the LT1 here is the procedure, it may work with the 6 cyl too, the basic operation of the IAC is the same.
[ol][*]Depress accelerator pedal slightly.[*]Start and release accelerator pedal,run engine for 5 seconds.[*]Turn ignition "OFF" for 10 seconds.[*]Restart engine and check for proper idle operation.[/ol]
Hope this helps.
Another thought, did you check the operation of the tps sensor, making sure it springs properly.
Hope this helps.
