compression
so i finally got around to picking up a compression gauge and this is what i came up with
cyl 1 - 185psi
cyl 2 - 185psi
cyl 3 - 185psi
cyl 4 - 165psi
cyl 5 - 175psi
cyl 6 - 165psi
sounds good???
btw i dont understand why everyone btches about the plugs they were easy try doing plugs on a fwd 4.0 V8 northstar motor thats a btch
cyl 1 - 185psi
cyl 2 - 185psi
cyl 3 - 185psi
cyl 4 - 165psi
cyl 5 - 175psi
cyl 6 - 165psi
sounds good???
The Haynes manual says that the minimum compression pressure is 100 psi and the max variation between cylinders (highest to lowest) is 30%.
Based on that I'd say your 3.4 is in very good condition.
I had a guy complain to me one time about how hard the plugs where to get to in his 67 impala with a 327 cause it had headers on it. It is all relative. It is a pain if you do not own a swivel. LOL
3.8l without a swivel sucks.....but like you said its all relative to what pina means to you
