Clutch pedal won't return
Old Aug 6, 2011 | 06:57 PM
Bioguy's Avatar
Default Clutch pedal won't return
95 Camaro 5 speed 3.4L V6
I need help diagnosing my clutch problem please. I was driving down the road experiencing no problems at all when 2nd grinded when I downshifted on a routine turn. When I went to shift to 3rd I couldn't get in any gears. Once in a parking lot I realized that the clutch pedal wouldn't return to it's original position. I press down and it doesnt spring back more than halfway. The engine is unaffected and all the power works. I just can't get into any gears. I have not checked any fluids yet.
I would thnk that this must have something to do with clutch master cylinder or somewhere in the hydraulic assembly. More thoughts would be awesome.
Old Aug 6, 2011 | 08:15 PM
BasicConcepts's Avatar
Technical User
Have you noticed any slipping in the clutch???
Old Aug 6, 2011 | 08:46 PM
yep could be the master cylinder and or slave cylinder, could also be the clutch plate has went to pieces. and check the fluid level.
Old Aug 6, 2011 | 08:50 PM
Bioguy's Avatar
I have not noticed the clutch slipping at all.
hunterscamaro
Nov 18, 2009 11:10 PM
Skippysnax
Mar 3, 2009 12:09 PM
brandino
82-92 V8 Tech
Jul 9, 2007 01:21 AM
Gordon24Camaro
Mar 4, 2007 03:54 AM
jayd_21
Nov 3, 2006 12:36 AM
