clutch, cylinders, or bearing issues
Old 08-22-2010 | 02:00 PM
thor9812's Avatar
Default clutch, cylinders, or bearing issues
In reading several threads not sure which one. My symptoms on my 99 v6 5sp camaro is that; 1st shifting into reverse is becoming an issue, 2nd hard to shift into second sometimes. If I pump the clutch a second time, it will shift then. 3rd rough idling. Lastly, in pressing the cluch shifting into 1st from a stand still, car will take off sometimes while clutch engaged. The reservoir does have fluid and I've read if it doesn't or you have to refilling it then it is the cylinders? Your thoughts?
Old 08-22-2010 | 02:26 PM
To get things straight, the clutch is engaged when your foot is off the pedal, it is released when you depress the clutch pedal. From the symptoms you are describing, the clutch is not completely releasing. If the fluid level is holding full, then either the master or slave cylinder could be bad or the system has air in it and needs to be bled.
As for the rough idle, that is a different problem unrelated to the clutch. You may want to change plugs & plug wires, new fuel filter, new air cleaner. Is the service light lit? If it is, get the car scanned.
Old 08-23-2010 | 11:46 AM
thor9812's Avatar
Pete,
Thanks for the info I am going to do that. Process of elimanation. Bleed the line 1st. Now if I knew how. lol Thanks
Old 08-23-2010 | 05:47 PM
BasicConcepts's Avatar
Technical User
if theres no bleeder valve on the slave then get ready to build those muscles in your left leg youll need to pump the clutch peddle like 5683545 times lol seriously alot its a btch
Chaotic94
09-27-2010 09:23 PM
Rob79
03-17-2010 08:05 PM
gdrnec
06-01-2008 12:41 AM
myslomaro
04-17-2008 12:22 PM
jbassiii
10-02-2006 04:55 PM
Quick Reply: clutch, cylinders, or bearing issues
