clutch cylinder problem?
RE: clutch cylinder problem?
where the hell did u find a slave for 60? they are like 130 online
and i ordered a SPEC stage 3+ clutch $530, a SPEC billet steele flywheel $230, and an upraded GM hydraulics kit $320. should have everything I need.
i should mention, this thread is on page 2 already. ls1.com and ls1tech.com have precisely ZERO responses in the exact same thread i posted for them.
u guys rock, its why i have almost 4k posts here and a combined 300 on those sites
It's because we know things.
I was going to tell you to check the fluid level and tell you to bleed the clutch, but it looks like you've found your issue
By the way, I just set up a clutch, flywheel, master and slave cylinder on a Subaru today
ive got mine ordered. should be about a week before i get them probably [&o]. then im trying to decide if im going to do it myself or just pay someone so i dont have to deal with it. time and space is the issue
I got mine from the shop that fixed it. It came from a very reputable shop which did the install and the part and clutch came from a manufacturer down in Florida. They said it was totally new and wasn't a refurbished part. I have put 6k miles on it since then and have no issues to speak of and I do raise some cane with it every once in a while so I really feel like it will hold up....Hopefully to the 100 shot. I guess I will see.
I am having to replace the slave and clutch also and am paying just over $900 as well. Guy tels me it could be time to replace the whole tranny also and tells me it is going to run $3,500. Anyone know what a new tranny for an LS1 should cost?
jared121rs91
10-29-2010 05:19 PM
