cleaning engine bay
Old Jul 22, 2011 | 05:43 AM
bd92rs's Avatar
Default cleaning engine bay
what is the safest way to clean the engine bay on a 93 lt1 without damaging the optispark.
thanks
Old Jul 22, 2011 | 09:13 AM
Grandpaswagon's Avatar
Very carefully. I clean my engine bay a little at a time as I am working in there. I use damp towels and paint brushes and don't hit anything with a water stream.
Seriously, how dirty is the engine bay? Is it just the normal smutz that accumulates over 18 years? Do you have an oil leak?
As you know, the engine bays on these cars is very tight. There is not a lot of room in there and as such, most things that get grungy are near something that doesn't like to take a bath.
You don't want to spray the opti with water, or have a ton of water get all over it either. Also, the PCM is mounted up by the windshield on the passenger fender, and drenching that wouldn't be a good idea either. Take into account all of the different sensors, while you may not get them wet you don't want to hit the connectors with a power washer either.
Old Jul 22, 2011 | 09:54 AM
you can cover the alternator, opti and ecm with plastic. then you can hit it with degreaser and hose down. i have had a kid at the dealer do a wash job on the car, when he returned he informed me he had cleaned the motor and was very impressed with it. the whole drive home i was waitin for the opti to go wack. never did. soooo if your feeling lucky????
Old Jul 22, 2011 | 11:30 AM
bd92rs's Avatar
it's pretty nasty it looks like some one poured oil all over the entire area
that's why i want to clean it so i can tell if it still has a leak p.o says he fixed the leak but i'm not sure
plus it's just plain ugly
Old Jul 22, 2011 | 11:59 AM
scottrc's Avatar
Not a bad idea to have an air compressor nearby to blow out any moisture that might accumulate in hard to reach areas. In fact, try dry cleaning first with the air and a soft brush, you'd be surprised how much stuff can be removed without using water.
Old Jul 22, 2011 | 12:18 PM
I use engine degreaser and a power washer, covering anything vulnerable with plastic and wash away. Then I follow up by blowing off everything under the hood with air, and start the engine to let it cook dry anything else that may be slightly wet. Nothing beats a perty engine...
BlackBerlinetta
Jun 25, 2013 11:32 AM
v6baser
Apr 7, 2011 11:41 AM
black95z28
Apr 14, 2010 01:26 PM
slvrblt2
82-92 V8 Tech
Apr 22, 2009 04:27 PM
68cam
Aug 15, 2007 06:28 PM
