check engine light blinking?
Old 04-11-2013, 07:21 PM
Krusher RS's Avatar
Your O2 sensors not being installed into the exhaust has everything to do with why the codes were tripped. I'm surprised the light wasn't on before. Your engine is also most likely running too rich. Get those installed, clear the codes, and you should be good to go.
The light HAS been on since I got the car last fall, I just haven't been able to get the sensors installed due to the cranking problem. and yes its running rich, you can smell it.
Originally Posted by craby
rain was shorting the 02s somehow. lol, dont think 02s are to good for external applications. maybe in la. i would at the least notify the shop owner of the shoddy work. that is if the owner was not doin the work.
Thats the thing, I don't know where or when the exhaust was done . I've wondered myself if the PO done it. Whoever it was they were just plain lazy to not put them back in.
Old 04-11-2013, 07:23 PM
probly should invest in a couple new 02s. are all 4 of them hanging?
Old 04-12-2013, 04:21 AM
Krusher RS's Avatar
no, just the two down by where the cat was.
Old 04-12-2013, 06:18 AM
do you have two 02s in the exhaust closer to the engine?
Old 04-12-2013, 05:36 PM
Krusher RS's Avatar
Ones in the manifolds and these two that aren't installed in the exhaust so 4 total.
Old 04-12-2013, 07:51 PM
those back two are for checking the condition of your catalytic converters. do you have any cats? the hanging 02s may be simulators. im wondering if its been tuned and tune went bad. need more info on what you have.
Old 04-13-2013, 08:02 AM
Krusher RS's Avatar
Heres a run down of what I know. stock (probably) 3.8 with 5 speed, stock manifolds, true dual exhaust with dual flowmasters (no cats), cold air intake & filter. The PO "said" he just had $500 worth of exhaust work done right before I got it. It is new pipe, they just didn't put the 2 O2 sensors by the cat back in. They don't look like simulators, they looke like O2 sensors tied up by the tranny. Thats about all, as far as running goes.
Old 04-13-2013, 09:30 AM
installing the back 02s without cats is not going to do anything. you will still get codes because the cats are gone. im thinking the hanging 02s may be shorting. check your fuses to see if any are blown. not sure which the 02 heaters are on soooo check em all. you should look into simulators for the rear 02s
Camaroboi22
03-28-2013 07:15 PM
Chevykicksbut
10-28-2009 07:14 AM
Matsbox
05-20-2009 06:40 PM
Nitemare3o5
05-06-2008 07:55 PM
85Camarodude
09-12-2005 12:35 AM
Quick Reply: check engine light blinking?
