Changing fuel pump
Old Feb 3, 2013 | 06:28 PM
Camaroforlife's Avatar
Default Changing fuel pump
Recently figured out my fuel pump was bad. I decided to go with the "hatch" method. I bought the pump, and cut the hole. I'm not to sure of how well the pump will work.. I bought the spectra premium pump with sending unit.
1993-1995 Chevrolet Camaro Fuel Pump - Spectra SP3907H - In-Tank, Quad, OE replacement
any thoughts?
Old Feb 4, 2013 | 07:34 AM
1augapfel's Avatar
Spectra makes good stuff. You should be fine.
My 94 has almost 140k miles and AFAIK the pump is original. Can't be long now.....
Old Feb 4, 2013 | 10:32 AM
Chaotic94's Avatar
September 2011 ROTM
It'll do the job. No worries!
Old Feb 4, 2013 | 04:53 PM
Thanks for the replies !
My Pump will be arriving tomorrow, hopefully not too late so I can get my baby running again!
@1aug
Mine has about 144k miles, pump was still original up until a few months ago when it pooped out on me;
Old Feb 4, 2013 | 04:54 PM
Just a quick pic of what I did
Old Feb 4, 2013 | 08:34 PM
Greg08's Avatar
Whered u get the sheetmetal?
Old Feb 5, 2013 | 07:36 AM
I got it at lowes. It's took awhile to find some but eventually stumbled upon them.. There are many pre-cut sheets. Across from the mail boxes is the last place I thought to look.. Lol
Old Feb 5, 2013 | 08:26 AM
Excited to go home & change the pump!!
Old Jun 11, 2013 | 08:12 PM
KcLive's Avatar
How did you get the pump out? I have to change my pump and cut the access hole, removed the nuts holding the pump on, but can't get the pump out... do you need to remove the lines on top of the pump and tilt the pump to get it out? If so, how do you get the lines removed on top of the tank?
Old Jun 11, 2013 | 08:16 PM
Chaotic94's Avatar
September 2011 ROTM
Remove the lines from the pump and it should pull out
