-   93-02 General (https://camaroforums.com/forum/93-02-general-41/)
-   -   Car Wont Start! (https://camaroforums.com/forum/93-02-general-41/car-wont-start-25604/)
kamaro68 Mar 11, 2008 02:58 PM
Car Wont Start!
Help!
I am stuck at work!
I turned the key and nothing. I get all my power. I have power to seats, windows, radio..etc.
When I turn the key I don't even get a single click. I hear the fuel pump prime.
I checked all my fuses under the hood and everything checks out ok...
I was thinking maybe a bad solenoid but usually wouldn't you get a click noise at least? Dead silence over here
PS - not sure if it makes a difference or not but it is 80 degrees outside right now so internal temps are hot...
importmd Mar 11, 2008 03:23 PM
RE: Car Wont Start!
loose ground/battery connection?
z28pete Mar 11, 2008 03:27 PM
RE: Car Wont Start!
Is the security light coming on???
kamaro68 Mar 11, 2008 05:22 PM
RE: Car Wont Start!
Everything is clean and tight.
I get power to everything...except for starter.
z28pete Mar 11, 2008 07:00 PM
RE: Car Wont Start!
Repeat, is the security lite on the instrument panel coming on when you try to start the car??
kamaro68 Mar 13, 2008 12:08 AM
RE: Car Wont Start!
What is with the security light?
I asked the guy I bought it from if it had a factory alarm and he said no? There is a light that is always on. There is a little clear box in the center console that has adjustments for sensetivity. There is a two button alarm button wired in to the harness. The 2 button remote was hanging down near the gas pedal when I purchased the car so I hid it behind the cigarette lighter. I also found a one-button switch behind the fuse panel.
The alarm never seemed to work so I cut out the alarm horn. It was in the way of my installation of the K&N CAI.
Should I remove all those wires? Is that supposed to be the factory alarm? I would like an alarm but I was figuring on purchasing a new Clifford or Viper?
Saint_Ali Mar 13, 2008 12:11 AM
RE: Car Wont Start!
try unplugging the car battery for 15min and then hooking it back up and see if anything happens
6v49der Mar 13, 2008 01:15 AM
RE: Car Wont Start!
Ya this sounds like security issue, regardless of wether or not it had the factory security when you bought it, was your car orginally equipped with it?
kamaro68 Mar 13, 2008 11:54 AM
RE: Car Wont Start!
How would I even tell if it was factory installed. It appears to be a factory installed alarm. It is a very clean install. I can't remember the brand on the alarm however.
The car is still at the shop getting the starter changed...supposedly it is fried :(
1999TAmaster Mar 13, 2008 12:01 PM
RE: Car Wont Start!
Most came with alarms, So I am with these guys
