It can be done!!!!!!!
RE: It can be done!!!!!!!
ORIGINAL: JD1969
Because, unless you have a lift it is a big pain, and kinda dangerous. Personally I thinks it's more of a pain pulling motors out the bottom, I have done both and would rather pull them out the top.
ORIGINAL: importmd
why didnt you drop it through the bottom? you dont have to remove anything from the motor, and it takes 2 hours
Kinda funny how everybody has always said that it can be done. Now all of a sudden its like " well duh, everybodys done it." And Spartan.... yes I do. Make sure its long enough so that I can wrap it around your neck and drag you by it. How many people have done this, dead of winter, in a 12X18 garage?
ORIGINAL: Chappie99
I did mine out of the top as well. Had to take the intake off, as well as some other things. What did you do about the fuel lines? I couldn't get them off so I cut them. Spent freakin forever just trying to fanangle them off, and just got sick of it.
Seriously, you cut them? They make tools to disconnect them. I spent $18.00 on two tools, a 5/16th and 3/8ths tool. Just spread the tool and push and pull. Took all of .30 seconds.
ORIGINAL: M*******LT1
now lets see you get the new motor in there Chappie....
ORIGINAL: Chappie99
I know I got the tool, but for some reason I just couldn't get them off...You know how it is when you can't get something and you just get frustrated. So I cut them haha. Oh well it all worked out in the end
#20
ORIGINAL: armynatguard18
On a different note, is there a trick on removing the crank pully? My gun wont break it loose, and I just about shot one of my nuts through my cover-alls while ****ting myself trying to use my breaker bar.
